Create Kanban project with sample data in Jira Cloud
yuvalp October 1, 2018
Following tutorials I don't see the option to create Kanban project with sample data currently in the Jira cloud
Was it changed?
Does  this option still exists in the Jira Cloud?
7IjoBa9
2 accepted
4 votes
Andy Heinzer
October 1, 2018
There still is a way to do this, but not currently through the project creation menus in Jira Cloud.  Instead you can go to the Board management view and select the option to Create Board.  The popup that appears here will let you create a new kanban board and then do so with sample data (which in turn creates a new project and a new board).
If you're having trouble finding that manage boards page you can navigate directly to
https:// [yourAtlassianCloudsitename] /secure/ManageRapidViews.jspa
Onder Ozcan
Hi Andy,
That'll do the job.
Onder
Jaime Capitel (resolution)
I can confirm this still works in April 2021!
Lucas Modzelewski _Lumo_
March 2022, still works :) or /jira/boards
Mike Durante February 5, 2025
Does this still work in 2025?
Andy Heinzer
February 6, 2025
Yes, it still works.  Admittedly the URL I posted automatically just redirects to /jira/boards. But otherwise the create board button on that page still has the same options for creating a scrum/kanban board with sample data.
This might not work if you only had Jira Service Management or Jira Work Management as this boards page is specifically for Jira (previously known as Jira Software).   Or it might not work if you are not a Jira Admin, as this requires the ability to create a new company managed project.
Mike Durante February 6, 2025
@Andy Heinzer Are you able to post a screen shot please. No issues with permissions.
Andy Heinzer
February 6, 2025
Sure thing,
Like # people like this
Fabrizio Pinna
February 20, 2025
I'm Sorry but it returns "Unexpected failure occurred. Importer will stop immediately. Data may be in an unstable state" when i try to create board. I'm on free plan.
Jugurtha Lafi
February 12, 2020
THat worked for me too!!! :)
Christopher November 18, 2024
Does this work for IT Sample Data too? If so, where do i go?
Christian Pedersen
January 9, 2019
Thanks a lot. I had similar problem as OP
