Subtasks inherit their Security Level from their parent, but there are ways to set subtasks to a different security level.
However, I note that you tagged your post as using the Free plan. Security Levels can't be customized in the Free plan.
@Trudy Claspill hello I activated the 30 day trial of the premium version and I can use the security level now, but I can't establish them on the subtasks it's grayed out
What are you trying to accomplish by setting a security level for the subtask but not for the parent issue?
@Trudy Claspill I would like to hide certain subtasks according to very specific roles as to the task it must remain public
In the Premium instance to which I have access, I don't see the Security Level field at all on any type of task. Instead issue security is set by clicking on the padlock icon at the parent issue level.
On a Subtask if the parent doesn't have a security level set, then the padlock icon doesn't appear at all. If the parent does have a security level set, then in the subtask the icon is present and I can click on it to display the inherited security level, but I can't change the level for the subtask.
I tried to use an Automation Rule to set the security level on the subtask to something different. The rule said it ran successfully, but the security level was not actually changed.
I've read that you can change the security level on a subtask using the REST API, but I haven't tried that.
I believe to have a security level on the subtask at all you are going to have to apply a security level to the parent issue. So you would need a security level defined that allows people to see the parent, and a separate security level that could be used to hide issues. You could then try to apply that second security level to the subtask via the REST API.
You can not set a security level in the UI, subtasks take their level from their parent issue (because they're a fragment of that issue)
There was a bug in the REST API that let you set different levels on sub-tasks, but it may have been fixed...
I noticed that, in my environment, when I send an "editmeta" GET request on an subtask whose parent has a security level, Jira reports it can be edited.
It seems Jira accepts the request, but does not do anything, so, if there was a bug, it's been partially fixed.
What do you think @Nic Brough -Adaptavist- ?
I agree, if you're finding you can't set a different security level on a sub-task with REST, then the bug has been fixed.
