smart values calculating cost of 2 fields.
Tomasz Osik October 19, 2023
Where I am making a mistake? I am having 3 fields:
Change Cost = read only
Original Estimates = to be populated
ML Estimates = to be populated
Automation to:
On transition
If any of value is present
calculate using smart value.
Smart Value:
{{#=}}{{((issue.Original Estimate}}) / 8) * 650 + (({{issue.ML Esitmates}}) / 8) * 750{{/}}
Cant get values or flashing unary operator. Seems like from simple calculation i have created monster that will not be working at all...
Can anyone advise me on this issue?
Best Regards
Tomasz
Marc - Devoteam
October 19, 2023
Hi @Tomasz Osik
What is the automation look like and what is the current error you are getting, when the automation rule is executed?
This detail level would help the members here to see if we can find a solution for you.
Thank you for response, i think i have fixed the issue by correcting equasion to:
{{issue.Change Cost.asCurrency("gb_GB")}}{{#=}}((({{issue.Original Estimate}} / 8) * 650) /3600)+(({{issue.ML Estimates}} / 8) * 750){{/}}
Missing brackets and i did not took into consideration that original estimates are always stored in seconds, therefore i had to divide this field by 3600second (this equates to 1 hour).... and it worked. However i cannot set up "£" currency.
Is smart value correct?
Thanks in advance.
Like Marc - Devoteam likes this
Marc - Devoteam
October 20, 2023
Hi @Tomasz Osik
I think the smart value in relation to the pound sign should be en_GB instead of gb_GB
Tomasz Osik October 20, 2023
Amended it... no joy so far.... will research it further
Bill Sheboy
October 20, 2023
Hi @Tomasz Osik
Adding to the earlier answer:
I am unclear why you are placing the Change Cost value next to the math operation.  Would you please explain?
For an example, please show some example values and your expected output (field set).  Knowing that may help the community to suggest improvements.
