the state field moved from place in project
evillacrez January 22, 2025
The status field has been moved in the project. If you are guided by the image, the status field is now displayed in the description fields, when it should be located in the context fields.
Karan Sachdev
January 22, 2025
Hey @evillacrez
This is due to a product experiment being run for a few sites (selected randomly).
Karan
Thanks @Karan Sachdev 👍
ureimers
January 29, 2025
 @Karan Sachdev Hi Karan,
how can we revert this? It's very annoying and all colleagues are complaining but we can't do anything about it.
In https://community.atlassian.com/t5/Jira-questions/solved-How-to-set-status-field-back-to-context-field-area/qaq-p/2920008 it was written, that this could be reverted by Atlassian. So how could this be done?
Ulf
Kim Nielsen _Admin konto_
September 24, 2025
i want it changed back as well, i experience the same issues, and  my colleagues too are complaining, please change it back, at least make it as an option for jira admins to change and not just lock the field.
Karan Sachdev
September 24, 2025
Hello All,
This feature is now rolled out to all sites, and we don't have a way to revert it. You may add your vote or feedback herehttps://jira.atlassian.com/browse/JRACLOUD-96142
Or add a comment on the community post: https://community.atlassian.com/forums/Jira-articles/Easier-status-updates-for-work-items/ba-p/3068881
Thanks!
FREE
