I downloaded free Jira trial version for understanding the workflow and automation of issue status.
I am unable to add the Automation plugin to my JIRA.
I was looking for a communication I received on this a couple of weeks back. If memory serves, given their acquisition of A4J, Atlassian was going to do away with the lite version or ability to install as a step toward their goal of integrating A4J into Jira natively. I will try to find the reference and share here.
Note I did find the email and noting that you are on server this does not apply. Now, it may be that Atlassian has some similar plans to integrate into a future server version but I don’t have insights into that. Moreover, as long as the addon is available in the Marketplace it should be installable.
Have you tried downloading the separately and then installing plugin manually from the UPM console (Add-ons >> Manage Add-ons)? Do you get any error message?
Now I am able to automate the status change.
Wasnot trying the right Jira automation trial version.
now all good.
