×I'm trying to create a project using rest api endpoint "/rest/api/3/project", I'm using leadAccountId key to assign a lead to the project which is throwing internal server error with "status code 405". please help me I have struck here for two days. thank you in advance
payload = json.dumps({
"notificationScheme": 10021,
"description": "Example Project description",
"lead": "<accountId>",
"url": "http://atlassian.com",
"projectTemplateKey": "com.atlassian.jira-core-project-templates:jira-core-simplified-process-control",
"avatarId": 10200,
"issueSecurityScheme": 10001,
"name": "New key",
"permissionScheme": 10011,
"assigneeType": "PROJECT_LEAD",
"projectTypeKey": "business",
"key": "NK",
"categoryId": 10120
Hello @Rajinish_Gaddam
Welcome to the community,
You can use the jira library for python. Here a code to create a project :
from jira import JIRA
jira = JIRA(basic_auth=('username", 'password'), options={'server': 'https://jiraURL'})
jira.create_project("projectKey","projectnaame","projectlead","projecttype")
Hope this helps
Hi @Mohamed Benziane ,
thank you for immediate response, but still I'm facing the issue.
the above code didn't work for me. it's throwing an error
text: The referenced project template was not found - the project has not been created.
response headers = {'Server': 'AtlassianProxy/1.15.8.1', 'Vary': 'Accept', 'Cache-Control': 'no-cache, no-store, no-transform', 'Content-Type': 'application/json;charset=UTF-8', 'Strict-Transport-Security': 'max-age=315360000; includeSubDomains; preload', 'Date': 'Fri, 07 Feb 2020 12:29:01 GMT', 'ATL-TraceId': '0e4d0d7a2dec6308', 'X-AACCOUNTID': '<accountId>', 'X-AREQUESTID': '448d-ae03-cb36f12b10de', 'X-XSS-Protection': '1; mode=block', 'Transfer-Encoding': 'chunked', 'Timing-Allow-Origin': '*', 'X-Content-Type-Options': 'nosniff', 'Connection': 'close'}
response text = {"message":"The referenced project template was not found - the project has not been created.","status-code":500,"stack-trace":""}
can you please let me know. what information goes into lead key? in the project
it's throwing an internal server error while I'm creating a project
"errorMessages": [
"Internal server error"
"errors": {}
Can you share the code that you use with the jira library please
@Mohamed Benziane sorry for delayed response
code:
jira.create_project(key="JP", name="jira_project", assignee="Rajinish Gadddam", type="Software")
Exception:
jira.exceptions.JIRAError: JiraError HTTP 500 url: https://<org_url>/rest/project-templates/latest/templates
response headers = {'Server': 'AtlassianProxy/1.15.8.1', 'Vary': 'Accept', 'Cache-Control': 'no-cache, no-store, no-transform', 'Content-Type': 'application/json;charset=UTF-8', 'Strict-Transport-Security': 'max-age=315360000; includeSubDomains; preload', 'Date': 'Sat, 08 Feb 2020 17:06:28 GMT', 'ATL-TraceId': '90c612ac36dbcd1c', 'X-AACCOUNTID': '<accountid>', 'X-AREQUESTID': '3c05740e-bb66-489d-be19-34f93ad1e0b3', 'X-XSS-Protection': '1; mode=block', 'Transfer-Encoding': 'chunked', 'Timing-Allow-Origin': '*', 'X-Content-Type-Options': 'nosniff', 'Connection': 'close'}
Can you try this please :
jira.create_project("JP", "jira_project", "Rajinish Gadddam","Software")
still facing the same issue @Mohamed Benziane
I'm using Jira cloud
url = 'https://<org>.atlassian.net/rest/project-templates/latest/templates'
error : 'The referenced project template was not found - the project has not been created.'
status_code: 500
for reference:
payload:
'name': 'jira_project',
'key': 'JP',
'keyEdited': 'false',
'projectTemplateWebItemKey': 'com.atlassian.jira-legacy-project-templates:jira-blank-item',
'projectTemplateModuleKey': 'com.atlassian.jira-legacy-project-templates:jira-blank-item',
'lead': 'Rajinish Gadddam',
'type': 'Software'
Are you sure that you have jira-software installed ?
I'm using jira cloud, is it any different form jira-software?. I'm trying to create a project using jira python module version (jira==2.0.0)
Can you use "Scrum" instead of "Software"
still same issue @Mohamed Benziane I'm not getting where I'm going wrong
ORGANISATION = "https://<ord>.atlassian.net"
jira = JIRA(basic_auth=('<email>', '<api key>'), options={'server': ORGANISATION})
jira.create_project("JP", "jira_project", "Rajinish Gadddam", "Scrum")
Ok i just tried this and it's working fine :
jira.create_project(key="Python",name="Create for python",assignee="mohamed.benziane",type="Software",template_name="Scrum software development")
here the liste of possible template:
# possible_templates =
[ # "Scrum software development",
# "Agility",
#"Bug tracking",
#"JIRA Classic",
#"JIRA Default Schemes",
# "Basic software development",
# "Project management",
# "Kanban software development",
# "Task management",
# "Basic",
# "Content Management",
# "Customer service",
# "Document Approval",
# "IT Service Desk",
# "Lead Tracking",
# "Process management",
# "Procurement",
# "Recruitment", # ]
thank you so much for your help @Mohamed Benziane you're a life saviour.
another approach to the same problem:
url = "https://<org url>/rest/simplified/latest/project"
headers = {
"Accept": "application/json",
"Content-Type": "application/json"
auth = HTTPBasicAuth("<email>", "<api key>")
project_payload = {
"name": "Jira_project",
"key": "JP",
"templateKey": "com.pyxis.greenhopper.jira:gh-simplified-kanban-classic"
response = requests.request(
"POST",
url,
data=json.dumps(project_payload),
headers=headers,
auth=auth
Hi @Rajinish_Gaddam ,
I can see everytime you have been chaning url value.
How you get correct url value to create a new project?
In my case I see list of projects here at
"https://myjirasite123.atlassian.net/secure/BrowseProjects.jspa"
@Bas sorry for the delayed replay, reason I have mentioned multiple urls because I have tried all the urls mentioned by different experts until I find authentic url and @Mohamed Benziane has given an appropriate answer to create project
Hello, I wanted to ask how I can get the: projectTemplateKey of my project so that the projects that I create are created under that same template assigned to other previous projects. Thank you
