Hello, I want to use a condition for the web-section inside a jira plugin.
But when I add
<condition class="com.atlassian.jira.plugin.webfragment.conditions.JiraGlobalPermissionCondition"> <param name="permission">admin</param> </condition>
I get an Caused by: java.lang.ClassNotFoundException: com.atlassian.jira.plugin.webfragment.conditions.JiraGlobalPermissionCondition
Can anyone help?
kind regards
Chris
Try to uncomment the jira-core dependency in your pom.xml and reimport all dependenciey
no this doesn't work and it is a little bit confusing that the class com.atlassian.jira.plugin.webfragment.conditions.JiraGlobalPermissionCondition is located in jira-api and in jira-core. :o
Hello, Christian.
Did you find any solution?
Thanks.
