I don't know if I should write this issue here, but I just don't know where.
Webhook worklog (created, updated) hook in issue (updated) event
P.S.
I'm using ngrok for debugging my web api app
Hi @ssavvidis , you can write here, but we need to get more information. You need to create a post which contains at least any information to be able to help you with the problem.
It is easy to test.
I just set webhook for the issue events (update create and delete) to post on my service
also, I did it to another endpoint worklog events so when I chage in issue worklog
webhook should rize worklog mehtod not issue one.
set webhook here www...atlassian.net/plugins/servlet/webhooks# by creating a new webhook.
json i have received in my service
"timestamp": 1664871587524,
"webhookEvent": "worklog_created",
"worklog": {
"self": "https://.....atlassian.net/rest/api/2/issue/76098/worklog/60614",
"author": {
"self": "https://.....atlassian.net/rest/api/2/user?accountId=5a3cf888a847e93dd0bf853a",
"accountId": "5a3cf888a847e...",
"emailAddress": "zz@zz.gr",
"avatarUrls": {
"48x48": "https://secure.gravatar.com/avatar/d0e9f0bc91335fa700c8217ff8c3079c?d=https%3A%2F%2Favatar-management--avatars.us-west-2.prod.public.atl-paas.net%2Finitials%2FSS-4.png",
"24x24": "https://secure.gravatar.com/avatar/d0e9f0bc91335fa700c8217ff8c3079c?d=https%3A%2F%2Favatar-management--avatars.us-west-2.prod.public.atl-paas.net%2Finitials%2FSS-4.png",
"16x16": "https://secure.gravatar.com/avatar/d0e9f0bc91335fa700c8217ff8c3079c?d=https%3A%2F%2Favatar-management--avatars.us-west-2.prod.public.atl-paas.net%2Finitials%2FSS-4.png",
"32x32": "https://secure.gravatar.com/avatar/d0e9f0bc91335fa700c8217ff8c3079c?d=https%3A%2F%2Favatar-management--avatars.us-west-2.prod.public.atl-paas.net%2Finitials%2FSS-4.png"
"displayName": "my name",
"active": true,
"timeZone": "Europe/Athens",
"accountType": "atlassian"
"updateAuthor": {
"self": "https://....atlassian.net/rest/api/2/user?accountId=5a3cf888a847e93dd0bf853a",
"accountId": "5a3cf888a847e93dd0bf853a",
"avatarUrls": {
"active": true,
"created": "2022-10-04T11:19:47.524+0300",
"updated": "2022-10-04T11:19:47.524+0300",
"started": "2022-10-04T09:00:00.000+0300",
"timeSpent": "4h",
"timeSpentSeconds": 14400,
"id": "60614",
"issueId": "76098"
You need to tell people what the problem is if you want help from them.
