×https://confluence.atlassian.com/clean/advanced-cleanup-1018789335.html
when i am trying to perform the activity i am getting the error at the below statement
def viewFieldScreens = new ViewFieldScreens(fieldScreenManager, fieldScreenFactory, fieldScreenSchemeManager, workflowManager)
can some one help
Static type checking] - Cannot find matching method com.atlassian.jira.web.action.admin.issuefields.screens.ViewFieldScreens#<init>(com.atlassian.jira.issue.fields.screen.FieldScreenManager, com.atlassian.jira.issue.fields.screen.FieldScreenFactory, com.atlassian.jira.issue.fields.screen.FieldScreenSchemeManager, com.atlassian.jira.workflow.WorkflowManager). Please check if the declared type is correct and if the method exists.
3. Delete unused screens:
import com.atlassian.jira.issue.fields.screen.FieldScreenFactory
import com.atlassian.jira.issue.fields.screen.FieldScreenManager
import com.atlassian.jira.issue.fields.screen.FieldScreenSchemeManager
import com.atlassian.jira.web.action.admin.issuefields.screens.ViewFieldScreens
import com.atlassian.jira.workflow.WorkflowManager
def fieldScreenManager = ComponentAccessor.getFieldScreenManager()
def fieldScreenFactory = ComponentAccessor.getComponent(FieldScreenFactory.class)
def fieldScreenSchemeManager = ComponentAccessor.getComponent(FieldScreenSchemeManager.class)
def workflowManager = ComponentAccessor.getWorkflowManager()
// use StringBuffer to spit out log to screen for ScriptRunner Console
def sb = new StringBuffer()
sb.append("Delete unused screens:\n");
fieldScreenManager.getFieldScreens().each { fieldScreen ->
//find all screens with no (or only null/previously deleted) screen schemes or workflows
def allEmptyOrNull = true;
viewFieldScreens.getFieldScreenSchemes(fieldScreen).each { fieldScreenScheme ->
if(fieldScreenScheme != null) {
allEmptyOrNull = false;
return;
if(!allEmptyOrNull) {
return;
viewFieldScreens.getWorkflows(fieldScreen).each { workflow ->
if(workflow != null) {
return;
if(allEmptyOrNull) {
fieldScreenManager.removeFieldScreen(fieldScreen.getId())
sb.append("${fieldScreen.getName()}\n")
return "<pre>" + sb.toString() + "<pre>"
Hi @Suresh Kumar Welcome to Atlassian Community!
Script you are using is for JIRA Server and JIRA Data Center. It doesn't work on JIRA Cloud.
For JIRA Cloud, I am not sure how bulk deletion work in JIRA Cloud but Atlassian is working on, you can vote this issue :- https://jira.atlassian.com/browse/JRACLOUD-71733
Some example for bulk deletion :-
https://github.com/cjlittle/jira-scripts/tree/main/scriptrunner-cloud
V.Y
Vikranth our Jira is clustered environment and for deletion of workflows and other things its all working fine for deletion only for the unused screens we are facing issues.
with the error attached earlier. all i want is someone check the script and help me where the issue is.
this is where i am getting error.
@Ram Kumar Aravindakshan _Adaptavist_ Kindly suggest. Following script is not working when cleaning unused screens using script console :-
Getting error :-
groovy.lang.GroovyRuntimeException: Could not find matching constructor for: com.atlassian.jira.web.action.admin.issuefields.screens.ViewFieldScreens(com.atlassian.jira.issue.fields.screen.DefaultFieldScreenManager, com.atlassian.jira.issue.fields.screen.DefaultFieldScreenFactory, com.atlassian.jira.issue.fields.screen.DefaultFieldScreenSchemeManager, com.atlassian.jira.workflow.OSWorkflowManager)
at Script811.run(Script811.groovy:12)
return;
return;
return;
@Suresh Kumar , if you use JIRA 8, constructor of class ViewFieldScreens looks like
public ViewFieldScreens(FieldScreenManager fieldScreenManager, FieldScreenFactory fieldScreenFactory, FieldScreenSchemeManager fieldScreenSchemeManager, FieldScreenService fieldScreenService, WorkflowManager workflowManager, JiraAuthenticationContext jiraAuthenticationContext, com.atlassian.webresource.api.assembler.PageBuilderService pageBuilderService)
so, the working code looks like this
import com.atlassian.jira.bc.issue.fields.screen.FieldScreenService
import com.atlassian.webresource.api.assembler.PageBuilderService
def fieldScreenService = ComponentAccessor.getComponent(FieldScreenService.class)
def jiraAuthenticationContext = ComponentAccessor.jiraAuthenticationContext
def pageBuilderService = ComponentAccessor.getComponent(PageBuilderService.class)
def viewFieldScreens = new ViewFieldScreens(fieldScreenManager, fieldScreenFactory, fieldScreenSchemeManager, fieldScreenService, workflowManager, jiraAuthenticationContext, pageBuilderService)
return;
return;
return;
Hi @Suresh Kumar,
Please confirm if you are running on a cloud-based environment or a Server / DC environment?
If it is the former, the approach you are currently using will not work, mainly because the API is different, and there is no access to the Jira Server / DC APIs like com.atlassian.jira.component.ComponentAccessor
Thank you and Kind regards,
Ram
its not working on Jira Server environment.
