×How do i know the issue severity from jira_issue table.
I have searched in Jira issue table, but it seems to be a custom field. any one share me the info to get this?
By default Jira doesn't have a severity field, it uses priority.
You can add severity as a custom filed, type drop-down single select.
BR, Olga
Shall I use the priority values 1,2,3,4,5 as severity? which is available in the priority column in jira_issue table ?
You can use whatever suits you. It's a custom field, use something everyone will understand.
For example
S1 - Critical
S2 - Major
S3 - Moderate
S4 - Low
OR
Sev 0
Sev 1
Sev 2
BR, Olga
I have taken stringvalue column in customfieldvalue table.
Thank you for your help.
Dhandapani
