In an a issue while we change the filed values without any transition, that change should capture and send custom event notification.
For that event I'm using Scrip runner addon, but not getting any notifications can you help me out with some script for the custom mail event
Hi @Vijay ,
in order to do that you need to setup a custom listener through ScriptRunner update event, check if your custom field has been changed and send a custom email notification.
Useful link :
Hope this helps,
Fabio
Hi @Fabio Racobaldo _Herzum_ I have added the Script Runner Listener and changed the custom filed values but it is showing as not run yet
Hi @Fabio Racobaldo _Herzum_ I have added, but it was updating on the custom fields by adding new values
