worklogAuthor operation - possible issue
Michael Killeen September 11, 2018
This filter works
worklogAuthor = currentuser()
This finds nothing
worklogAuthor = currentuser() AND worklogDate >= 2018-01-01 AND worklogDate <= 2018-12-31 ORDER BY Rank ASC
Work has been this year!
Michael Killeen September 13, 2018
support had a look,
They suggest may have to with plugin from tempo
Susanne Götz _Tempo_
September 13, 2018
Hi Michael,
When work is logged in Tempo, the worklogs are stored in the Tempo database and the time spent on the issue is updated to JIRA. Therefore the worklogauthor function will not work for worklogs created with Tempo
(see also https://tempo-io.atlassian.net/wiki/spaces/TEMPO/pages/153419777/How+does+Tempo+integrate+with+the+Time+Spent+field+in+Jira).
Susanne Götz
Tempo team
Thank for feedback
Using cloud, what I can find is that re-indexing just happens- no option to run
SMS
September 11, 2018
Hi Michael,
The Cloud Support team can run a reindex for you, but you'll need to open a support ticket to request it.
My recommendation would be to open a ticket for this anyway, since they'll be able to look at your instance and work with the data you have in order to understand what the issue is.
Shannon
Adrián Plaza [DEISER]
September 11, 2018
Hi @Michael Killeen,
Welcome to this community :)
In my company Jira instance, the last filter works fine, is your Jira instance fully reindex?
Adrián.
