Hi everyone,
I’m looking for a solution to efficiently manage and export our Software Requirements Specification (SRS) documentation using Jira Cloud.
Our Setup:
The Challenge: Our goal is twofold:
What We’ve Tried:
My Question: Could anyone recommend a tool or approach for Jira Cloud that:
Any suggestions, workarounds, or experiences with similar setups would be greatly appreciated.
Thank you in advance for your help!
Advanced Roadmaps:
Xporter:
PDF Exporter & Word Exporter:
These are great recommendations! Advanced Roadmaps helps with hierarchy and organization, while Xporter and PDF/Word Exporter handle structured exports. If you’re using Confluence, it can also streamline documentation and export needs. Combining these tools should give you the flexibility to manage and export your SRS documentation efficiently!
Thank you Sanam!
I found a solution by working with the Xporter tool.
