Regarding Mobility for Jira
Anuj Tripathi
April 29, 2015
I just found out that "Mobility for Jira" add on is missing from market place. I want to use JIRA Connect Professional app on my Apple mobile for Tracking my development stuff. Do any one have any idea for this?
Anuj
Aleksander Gruca
January 20, 2016
Hi
Do you Guys know is Atlassian going to run Mobility on Cloud version soon? As I strugeling to connect to my account (Jirra and Confluance) form Jirra Connect mobility app  with no sucess form.
I have installed  all needed ads-on (i expect) . But I still getting during login:
"This App requires the Mobility for JIRA add-on from Atlassian Marketplace but add-on was not found on your JIRA system ."
I seriously need it .
AG
Anuj Tripathi
May 4, 2015
Thanks for Confirmation. Need to look for another app.
Anuj
Luciano Fagundes
May 1, 2015
Anuj,
Just to complement John's response above, please find below the addons list that is compatible with JIRA Cloud.
https://confluence.atlassian.com/display/Cloud/Atlassian+Cloud+and+Add-ons
Hope it helps!
Cheers
L.F
João Palharini
April 30, 2015
Hi Anuj!
This add-on is not supported by JIRA Cloud instances. Unfortunately, at this point in time, the only way to have it enabled is by having a JIRA Server instance.
Cheers!
Joao
