Reindex problem in workflow transition
Roger Ares
July 5, 2012
We have an issue in a state A and we promote the workflow manually changing this state to B. While the status showed in the view screen of the issue is B, when we execute a JQL searching this particular issue the result is status = A. Then, doing a full reindex of the platform, this problem is solved and the statuses are the same in both sides.
So, it is a clear evidence that the indexes are not updated properly during the transition of the workflow. We would like to know the behaviour of Jira when we have custom workflow post-functions that reindex the issues, and also the effects that can have a scheduled task that is changing some fields of the same issues that are affected by the workflow's transitions.
Do you know where can be the problem? This has happened in 4 out of 1200 issues.
Let me know if you need more details.
Thanks a lot.
Salome Khaindrava
Chack known problems with 3rd party apps - https://confluence.atlassian.com/jirakb/known-major-problems-with-3rd-party-apps-in-jira-946618564.html
We had the same problem and the cause was plugin META-INF KFT - Email This Issue.
We disabled it and problem was fixed.
Tomáš Štalmach August 11, 2015
Hey,
Did someone figured out how to fix this issue?
We have same problem after 3 years of publishing this question.
Harry Chan
August 25, 2012
Do you know what do you have in your post functions? Check if the order is correct and it is indexing there.
Gisela August 25, 2012
Rares, I m having the same problem, do you discover anything?
I found the issue https://jira.atlassian.com/browse/JRA-29424, I think maybe is releated.
Radu Dumitriu
July 9, 2012
I think that you should open up a bug and include the logs: https://jira.atlassian.com/browse/JRA This may be related to lucene, not Jira or to the plugins firing up on the transitions (if any), but check first the opened bugs:
https://jira.atlassian.com/secure/IssueNavigator.jspa?sorter/field=created&sorter/order=DESC
