Releases from other projects in master project possible?
Systems Department
At our company we have 10 to 12 difference pieces of software we develop. All of this software will then periodically be combined together into a large installable. Each piece of software has it's own version number system unrelated to the others. We would like to make a JIRA project for the assembly of the installable by a special team. Ideally we would like to be able to choose released versions of the other software form their respective projects when making the ticket so it is all cross-referenced. ie.. Installable 1.0.0 has softwareA 4.3, softwareB 7.2, etc etc. We can do this manually obviously using tickets. But I was wondering if there is a more automatic way anyone can think of?
What I imagine is creating a new ticket for software packaging. And then one would be able to choose from dropdown the released versions of software from other projects. When one would view the ticket you would see what software had gone into it with click backs to their projects.
Thanks anyone!
Gwilym Hughes January 1, 2014
Hi Jeremy,
You could try making an Epic for each installable. It could be modified to basically be a dummy version, as these are the only things that really work cross project in terms of linking things.
For a better answer though, it would be good to know what you use versions for in your system? Are they to track releases to a testing system, are they done using Bamboo?
Also, what is the relationship of feature to release, and release to installable? Is it one feature per release or many to one (or many to many)?
Thanks and good luck!
