Remaining estimate purge as post function - doesn't work
Rumceisz
Dear All,
we set 'Purge Remaining estimate' as post function for a workflow transition but it doesn't work: the estimation is still there after the transition took place.
Can you please help what did we wrong? Or we should set a different field??
Thanks in advance,
Rumi
RambanamP
July 29, 2013
you have to Use the standard post function 'Update Issue Field' and leave the Field Value empty.
check this issue
https://jsutil.atlassian.net/browse/JSUTIL-79
Rumceisz
many thanks!
