I am unable to remove the text from migrated fields in a team managed project - can anyone help?
Hi @Niki Woolston ,
Atlassian is assisting us in removing the 'migrated' details from the field descriptions. You can reach out for support by creating a ticket at https://support.atlassian.com/contact.
Additionally, there is an open feature request for this:
Give users the option to remove the migrated text from fields when using JCMA
Also, if you feel my input help you please accept the answer.
Bhushan
Thanks Bhushan, apologies I just saw your reply when I was looking for info to see if this had been fixed! any updates?
This isn't exactly an answer in the way you're looking for, but if all you're looking for is to hide that text only for yourself, you could try to hide that element using your preferred adblocker.
Usually they have an option to "Hide something on this page" or "Block ads on this website" that you can use.
