Removing the right to delete Jira issues
Jo
Is there a way to prevent regular users from deleting issues in Jira?
Bhushan Nagaraj
July 29, 2014
Go to Project permissions and remove the groups/roles you would like to block from "Delete issue" permission.
https://confluence.atlassian.com/display/JIRA/Managing+Project+Permissions
Luciano Fagundes
July 30, 2014
To validate if the permissions change worked (as mentioned by Bhushan) you can run the permission helper to do so:
https://confluence.atlassian.com/display/JIRA/JIRA+Admin+Helper#JIRAAdminHelper-PermissionHelper
Cheers
Luciano Fagundes
