Hello
I have an issue with renderer.
For all of our projects, the renderer is not working properly on create issue screen only.
Example for requirement field on a project, for create issue view:
For this example I added a photo and a test in bold.
I would like to have the photo and the text in bold directly ....
Once created the view or edit screen providethe correct view:
The image or the bold message is correctly illustrate ....
Field is declared in wiki renderer, this is ok, but on create screen this is not displaying correctly .
Can someone guide for a resolution ?
Thx
Since the Create Issue screen still uses the old view, the text Wiki renderable fields such as the Description field are displayed in text mode which does not format the markdown syntax. We have a feature request open for the same and our development team is currently working on it so we can expect this feature to get released soon. This can be tracked here-
I would encourage you to visit the suggestion page linked above and click the Vote and Watch links near the top right to show support for the feature. By doing this, it will ensure you're proactively informed of progress and updates going forward in accordance with our Implementation of New Features Policy. we would appreciate your feedback on the feature, you can do this by leaving a comment on the ticket, this helps us prioritize and understand the use case of the feature request.
