Reopen Issue resolution not clear in issue list
Jiannan Tang
Hi:
I had added the post function at reopen transtation.
When I reopen issue, the resolution is Unresolved at detail page.
But the resolution in issue list page still Fixed?
Why?
Jiannan Tang
The Resolution of the issue will be cleared. ” Post function must be first place.
Chaithra N
May 12, 2013
Can you reindex JIRA & see if the resolution shows the same both on View Issus & Filter page.
If this resolves your problem, then there is index problem.
Check if you have added any custom postfunction at the Reopen tranistion & it might be creating the problem.
