Report of all active Jira projects and project leads
Keshni March 19, 2019
What query can I use to give me a list of all active Jira projects with the project leads.
Thank you :)
3 votes
Chander Inguva
March 19, 2019
Hey Keshni,
If you have access to Jira database you could pull data using following SQL Queries
  • The first query gives project key as well as number of issues in it along with project lead
  • While the second query gives last updated with project key and project lead
select p.pkey,p.pcounter AS number_of_stories,p.LEAD from project p ORDER BY pcounter ASC;
SELECT DISTINCT p.pkey,p.LEAD,MAX(i.UPDATED) as "Last Updated"
FROM jiraissue i
INNER JOIN project p
ON p.ID = i.PROJECT
GROUP BY p.pkey,p.LEAD
ORDER BY MAX(i.UPDATED) ASC
Hope this helps you get started
Chander Inguva
Casper Hjorth Christensen
Hi Chander
You seem quite able with SQL, where I am not, and therefore I hope you can help me out.
I need to get the following from our MSSQL DB.
A list of all projects, with:
Last issue updated date
And the user who updated it
Project Lead
Project Lead Email
Robert Stumpe September 12, 2019
i needed this information too, so i just queried it from the database (mysql)
SELECT p.pname, p.pkey, u.display_name, u.email_address FROM jiradb.project p, jiradb.cwd_user u where lower(u.lower_user_name) = lower(p.lead);
this will give you the projects (without projects where the lead is no longer in jira)
Markeese Martin March 7, 2025
Does anyone have an Oracle Query?
Seenivasan Mohanraj March 25, 2024
I need to extract all project info from Jira database like below using SQL query please help.
Project Key
Project Admin
Project Lead
Projecct lead email
Project name
Hi @Chander Inguva ,
Thank you so much for this!! It helped...
How can I can the project name rather than the project key?
Chander Inguva
March 19, 2019
Just add p.pname Keshni.
Glad i could help you
Chander
Like Bipin Brahmanandan likes this
Thank you :)
Chander Inguva
March 19, 2019
Good luck Keshni
SreeKanth July 11, 2019
Hi @Chander Inguva
Project Key
Project Description
Project Lead
Project Lead Email
Project Category
Project URL
Chander Inguva
July 11, 2019
Hey Srikanth,
Try this SQL
select p.pkey as [Project Key], p.DESCRIPTION as [Project Description], p.LEAD as [Project Lead], cu.email_address as [Project Lead Email], pc.cname as [Project Category], p.URL as [Project URL] from project p
JOIN nodeassociation na ON na.SOURCE_NODE_ID = p.ID
JOIN projectcategory pc ON na.SINK_NODE_ID = pc.ID
JOIN cwd_user cu ON cu.user_name = p.LEAD
where na.SINK_NODE_ENTITY ='ProjectCategory'
Hope this helps
Chander Inguva
Like # people like this
SreeKanth July 12, 2019
@Chander Inguva  That saved my day thanks for the help.
Appreciate it.
SreeKanth
Chander Inguva
July 12, 2019
Glad i could help you @SreeKanth
Cheers
Chander
Deleted user June 28, 2022
@chanderIng
Hi Chander wondering if you could come up with a query to get the distinct projects in Jira using JQL
Thanks!  @Newelle Horn
Matthew Knatz
@[deleted]
JQL can't return aggregate data, so things like "Distinct" and "Group by"  which are standard SQL operations don't apply. To get distinct projects you can always hit the API and parse the data returned. Keep in mind that this only returns projects that the calling user has access to.
Jira Server/Data Center:
  • https://<your-jira-url>/rest/api/2/project
Jira Cloud:
  • https://<your-company>.atlassian.net/rest/api/3/project/search?jql=&maxResults=<some-large-number>
Reference: https://community.atlassian.com/t5/Jira-questions/Jira-REST-API-to-get-projects/qaq-p/728218
Like Robert Stumpe likes this
Om Joshi July 20, 2022
Hi @ Chander,
I am looking to fetch same information from my PostgreSQL database,
Project Key
Project Description
Project Lead
Project Lead Email
Project Category
Project URL
Project Create Date
Project Name
have tried to work out from your suggested queries but unable to do so. could you please advise.
awaiting your reply.
