×I've created search filters to pull the number of jobs completed for various financial years, for a certain team.
The results come to "1,000+" results. When i export the data (to then copy into a Google sheet), it only exports 1,000 results. Hence, for every financial year i'm pulling they are coming up with the exact same number of jobs completed - 1,000. Which has to be incorrect.
How can i ensure that i'm exporting ALL the results? I need the data to extend beyond a 1,000 count limit.
I've seen another similar question but the solution wasn't specified.
Hi @Tarfon, Carla ,
Hope you are doing well!!
I don't think so out of the box this is possible but I saw one article on the export issue more than 1000 through google Sheets.
Please have a look at the workaround How to export more than 1000 issues using Google Sheets.
Here is the list of workaround
Hope this helps.
Mayur
