Hello, it seems I've created a project using the wrong template.
I need to use the project name and project key to create a new one with the correct template.
Could you please support in deleting the current "GI_Platform_Regulatory_JP" project?
Thank you for your reply. But the owner of this project only sees summary and details in the menu, there is no "delete project"
They don't have the admin rights that enable them to delete projects.
Also, you can't re-use project keys without some complex manipulation of the database that you can't do on Cloud. (At least, this was the case last time I deleted in Cloud, it may have moved on by now)
Can the deletion be done by WhiteWater team? How can I request deletion to them?
