×I would like to require a text field (or a single-select dropdown) based on the value selected in the Component/s field. (The custom fields are Acceptance Criteria and Code review required?)
I have:
import com.onresolve.jira.groovy.user.FieldBehaviours
import groovy.transform.BaseScript
@BaseScript FieldBehaviours fieldBehaviours
def componentField = getFieldByName("Component/s")
def acceptanceCriteriaField = getFieldByName("Acceptance Criteria")
String componentValue = componentField.getValue()
if (componentValue == "AI Platform") {
acceptanceCriteriaField.setRequired(true)
else {
acceptanceCriteriaField.setRequired(false)
I am unable to make this work and could use some advice.
Hello Robbie,
I think the issue is that component/s is an array, and so a direct "==" comparison won't work.
Try something like this:
import com.atlassian.jira.bc.project.component.ProjectComponent
def componentField = getFieldById("components")
def componentValue = componentField.getValue() as List<ProjectComponent>
if (componentValue.any {it.name == "AI Platform"} ) {
else {
