We have installed the latest version of the JIRA and also downloaded the JIRA Suite utilies plugin. But when we use the Required field validator under the validator tab in the workflow and try adding the fields then the fields are not getting added and later we get an exception.
This plugin used to work fine when we had older version of jira and jira suite utilies.
