Required fields : Comment - does not work
Mohini P May 12, 2014
Hi JIRA developers,
Can you please let me know how the Validator = Required fields : Comment is to be used ?
I added this validator and when I was executing that transition, as expected it threw an alert that comment field is required. But after inputting the comment when I retry to run that transition, again shows the same alert:
"Comment is required"....
Please suggest.
I need to make it mandatory that when the user tries to execute that particular transition, he should add new comment first.
Fabio Racobaldo _Catworkx_
Another possible solution is to use JIRA BEhaviour Plugin.
This link explains you how to implement that https://jamieechlin.atlassian.net/wiki/display/JBHV/JIRA+Behaviours+Plugin#JIRABehavioursPlugin-RequireaCommentwhenthestateisReopened
Hope this helps,
Fabio
Uday Karthik Yadlapalli October 28, 2014
You can make the  'Comment' Field Required using Behaviours in Script Runner Plugin.
So whenever someone edits something it asks to put in a comment. It even works for transitions.
Check this link on how to do that:
https://jamieechlin.atlassian.net/wiki/display/JBHV/JIRA+Behaviours+Plugin#JIRABehavioursPlugin-Modifyfielddescriptions
You can Use Behaviours in Script Runner Plugin to set 'Comment' required everywhere, or use JIRA Suite utilities Plugin to create Validators to make 'Comment' required between Transitions. Both plugins are free too. https://marketplace.atlassian.com/plugins/com.onresolve.jira.groovy.groovyrunner https://marketplace.atlassian.com/plugins/com.googlecode.jira-suite-utilities
Mark Scott
June 23, 2014
I have the same problem as Mohini with the workflow extensions plugin. I have the "comment required validator" enabled for a transition & even if I enter a comment, it still pops up the custom error message. It is not correctly noticing that a comment has been entered & letting the transition continue. Any help would be appreciated.
Hello Mohini,
Andris's comment is right.
You need to perform the following steps:
1. Install JIRA MISC Workflow plugin (https://marketplace.atlassian.com/plugins/com.innovalog.jmwe.jira-misc-workflow-extensions). You need to add a free license in order to have this plugin in-place
2. Edit your workflow transition, adding "Comment Required Validator" provided by the installed plugin
3. Publish your workflow
Please, keep in mind that it is a not free plugin.
Hope this helps,
Fabio
Andris Grinbergs
May 12, 2014
You most likely have custom field "comment". Here is how you should create what you need: https://confluence.atlassian.com/display/JIRA/How+to+configure+comment+field+to+become+mandatory+in+workflow+transition
I have already done it. It gives additional validator called Required fileds : Comments right?
That seems to be not working
Andris Grinbergs
May 12, 2014
No, it should give validator called Comment Required Validator. Comment is not really a field.
Mohini P May 13, 2014
may I know what is the name of that addon. I am not able to find anything else apart from what I have already added. I cannot see Comment Required Validator!
Mohini P May 20, 2014
does anyone have answer to this question?
