Required fileds are not actually required
nir.porat
April 6, 2020
I had defined some custom field on a project and defined them as "Required"
When I create an issue there is not asterisk red mark and i can open cards without it...
shetty
April 6, 2020
@nir.porat
Check for field configuration associated with project
Navigateion - Project settings -> Fields -> edit Configuration -> search for field
Note field configuration is separate for these project else it will have impact on projects associated with it
