Required power script to trigger event when the new custom filed (additional watchers) is filled or
Ashok
December 25, 2022
Hi Team,
Since regular user with write access cannot use CSV file to fill in Watcher field.
Here is the workaround implementation.
  1. Create a custom people field called "additional watchers"
  2. Create power script to trigger event when the new custom filed (additional watchers) is filled or modified, to set the value into watchers.
Can you help with Procedure & script
Ashok
Amelie Winkler _Appfire_
@Ashok – Amelie from the Power Scripts team here! Have you tried opening a ticket with our support? They'll be able to help you set it up and write a custom script!
Cheers, Amelie
