Required web link
anne.gerten
we have a process step where certain Jira ticket types (initiatives) should have a web link attached.
I know, it is possible to add web links to Jira tickets.
My question is, is there any way to make it required so a certain ticket type needs to have a web link. Ideally I would want to have a web link field that can be named and a clickable weblink value.
Thanks!
Samuel Gatica _ServiceRocket_
Hi @anne.gerten
To enforce that certain Jira ticket types (like initiatives) must have a web link attached, you can approach it in the following ways:
1. Custom Field Requirement:
  • Create a Custom URL Field:
    Create a custom field of the type URL or Text Field (Single Line). This field can be used to store the required web link.
  • Set Field as Required:
    Use Jira's workflow validator to make this custom field required during specific transitions. This way, the user won't be able to move the issue forward without providing a link.
2. Validator in Workflow:
  • Add a Validator:
    In the workflow for the specific ticket types, add a validator to the transition that requires a web link to be provided before moving the issue to the next status.
These approaches allow you to enforce the attachment of a web link to certain ticket types, ensuring compliance with your process.
Hope this helps
Best regards
Sam
John Funk
Hi Anne,
You can create a custom field of URL type to story the link. And then make that field required.
