The workflows look the same, but the resolution screens are different. How do I fix this, so the custom fields match on each project?
If you have configured the exact same screen in the workflow, and they show up to the user differently, it's most likely because there is a context on the custom field that did not show up. You just need to add the new project in the customfield context.
Regards
