Resolve issue screen for QA
Nilophar Mujawar October 10, 2012
For QA resolve issue screen is not visible.
By default developers having permission to resolve the issue.
I have updated default permission schemes ---> Permissions-->Resolve Issues
and added permission to tester using group,single user and project roles still it is not displaying Resolve screen for Tester.
How can I update it?
Arthur Gonçalves
October 10, 2012
Hello Nilophar,
Some things that I recommend you to check:
  • is the workflow with this screen published or just still as draft?
  • are you restricting this transition to specific users, upon using validators?
  • is the Screen Scheme properly associated with your project?
Arthur Gonçalves
Nilophar Mujawar October 11, 2012
Hello Arthur,
workflow with this screen published.
Will you please elaborarte rmaining two points?
Nilophar
