Restarted server and recevied this error: (before this, had no issue at all)
Failed to start JIRA due to a build number inconsistency. The data present in your database is newer than the version of JIRA you are trying to startup. Database version is: 6124 JIRA app version is: 6099 Please use the correct version of JIRA. You are running: 6.0.3#6099-sha1:c2054781884e1c4d112ab9d1ae9f36bba0be0b25 |
2013-07-27 16:32:13 |
The database version table entry does show an upgrade to 6124 in a few of the rows, around 6/30, which was when I installed JIRA. Again, until I restarted the server, there were no issues.
Thanks.
Peter
Hi all!
I have a similar problem.
I have tried fix it by follow link:
https://answers.atlassian.com/questions/79340/jira-fails-to-start-different-database-version
But I don't know where configuration file to edit:
<properties>
<jira.version>4.0.1</jira.version>
<jira.data.version>4.0</jira.data.version>
<amps.version>3.11</amps.version>
</properties>
Please tell me where is the file.
I'm using standalone jira.
Thank a lot!
the proble is with your custom plugins? what are the plugins you deployed?
if any answer(s)/comments helped to you then don't forgot to accept as a answer/vote up!
if you have your own answer then add it here so it will help to other user aswell!!
yes, but they are in JAR format ... are you saying that they are causing the issues ?
when they were installed (from JIRA plugin management), they had not issues ... but this was the first time i restarted the instance.
i am not speaking about jira installation,
i am speaking about custom plugins which you have installed!
did you installed any plugin's in your instance?
Hmm ... this is an installed version, there are no pom's in the exploded WAR directories. I am not building this thing, running it from a web container.
the problem with the custom plugins so check your plugin poms
