Restful service (URL) for accessing Issues from JIRA system
PeriaDurai T
August 25, 2014
We are working for Pearson which has bought license from JIRA. They have bought SAAS model.
We are doing an enhancement where in we need to access/update the data in JIRA system.
They create stories/issues using JIRA. We need to access those RESTFul service and update the same in JIRA system.
Required from JIRA team
  1. In order to update the ISSUES/STORIES created at Agile menu, we need correct RESTFUL URL for updating the data.
  2. We need the exact JSON object and format so that we can update the correct values. Hence it would be great if we get the exact JSON structure.
  3. Do we need any authentication to call the RESTFUL service (POST)?
Thanks in advance.
Regards
Periyadurai T.
Nic Brough -Adaptavist-
August 25, 2014
See the standard documentation at https://docs.atlassian.com/jira/REST/latest/for points 1 and 2.
For 3, it's also hinted at in there, but to be explicit, yes, REST can only do things that the user you are logged in as can do. So if you do not authenticate, you can only do things that are allowed to "anonymous" users.
Thomas Heidenreich
August 25, 2014
You can see all this with the Rest API browser. Just install it and look at the GET values or POST examples.
The system needs the same authentication as when it is access normally.
