Restoring jira from XML - problem restoring ActiveObjects data for the plugin Email This Issue
Tomáš Burda April 6, 2017
we are using facing following problem:
Via jira gui (/secure/admin/XmlRestore!finish.jspa) I can see:
There was a problem restoring ActiveObjects data for the plugin Email This Issue(com.metainf.jira.plugin.emailissue) #7.0.21-jira6 plugin. Importing table AO_544E33_AUDIT_LOG_ENTRY failed. Please check the log for details.
Jira version: 6.4.14
Email this issue version: 7.0.21-jira6
We were using Mysql and we are migrating to PostgreSQL
Log output can be seen in comments.
We welcome any advice.
cuong hoang May 14, 2018
For us null values were causing this error. We found only 4 email log entries with null by querying the database, then we deleted through the user interface.
Thorsten Letschert _Decadis AG_
Any updates on this? We ran into a similar case last week and were unable to find a workaround yet.
@Tomáš_Burdahave you been successful in the meantime?
Tomáš Burda August 2, 2017
Hello.
i workarounded this by doing database dump
and restore to new db.
But we had to still use mysql.
2017-04-06 14:48:15,176 JiraImportTaskExecutionThread-1 WARN admin 875x162x1 17m1ei6 10.32.126.106,0:0:0:0:0:0:0:1 /secure/admin/XmlRestore.jspa [dvcs.dao.impl.CachingOrganizationDaoImpl] onImportCompleted - clearing cache !!
2017-04-06 14:48:15,181 JiraImportTaskExecutionThread-1 INFO admin 875x162x1 17m1ei6 10.32.126.106,0:0:0:0:0:0:0:1 /secure/admin/XmlRestore.jspa [jira.bc.dataimport.DefaultDataImportService] Importing data is 100% complete...
2017-04-06 14:48:15,181 JiraImportTaskExecutionThread-1 INFO admin 875x162x1 17m1ei6 10.32.126.106,0:0:0:0:0:0:0:1 /secure/admin/XmlRestore.jspa [jira.bc.dataimport.DefaultDataImportService] JIRA Data Import has finished.
Caused by: java.sql.BatchUpdateException: Batch entry 1,461 INSERT INTO public."AO_544E33_AUDIT_LOG_ENTRY" ("ADD_COMMENTS", "ADD_TO_WATCHERS", "ATTACHMENTS", "BCC", "CC", "EMAIL_BODY", "EMAIL_FORMAT", "EMAIL_SUBJECT", "FROM", "FROM_NAME", "ID", "ISSUE_ID", "ISSUE_KEY", "ISSUE_SUMMARY", "MAIL_AS_ME", "REPLY_TO_ME", "SENDER_KEY", "SENDER_NAME", "SEND_TIME_STAMP", "SOURCE", "TEMPLATE_ID", "TEMPLATE_NAME", "TO", "TYPE", "RECIPIENTS") VALUES ('0', '0', NULL, NULL, NULL, .......
was aborted. Call getNextException to see the cause.
at org.postgresql.jdbc2.AbstractJdbc2Statement$BatchResultHandler.handleError(AbstractJdbc2Statement.java:2598)
at org.postgresql.core.v3.QueryExecutorImpl$1.handleError(QueryExecutorImpl.java:459)
at org.postgresql.core.v3.QueryExecutorImpl$ErrorTrackingResultHandler.handleError(QueryExecutorImpl.java:348)
at org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:1836)
at org.postgresql.core.v3.QueryExecutorImpl.sendQuery(QueryExecutorImpl.java:1090)
at org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecutorImpl.java:398)
at org.postgresql.jdbc2.AbstractJdbc2Statement.executeBatch(AbstractJdbc2Statement.java:2737)
at org.apache.commons.dbcp.DelegatingStatement.executeBatch(DelegatingStatement.java:297)
at com.atlassian.dbexporter.importer.DataImporter$BatchInserter.flush(DataImporter.java:528)
... 24 more
[jira.bc.dataimport.DefaultDataImportService] Importing data is 89% complete...
2017-04-06 14:47:59,324 JiraImportTaskExecutionThread-1 INFO admin 875x162x1 17m1ei6 10.32.126.106,0:0:0:0:0:0:0:1 /secure/admin/XmlRestore.jspa [jira.bc.dataimport.DefaultDataImportService] Importing data is 90% complete...
2017-04-06 14:48:04,854 JiraImportTaskExecutionThread-1 INFO admin 875x162x1 17m1ei6 10.32.126.106,0:0:0:0:0:0:0:1 /secure/admin/XmlRestore.jspa [jira.bc.dataimport.DefaultDataImportService] Finished storing Generic Values.
2017-04-06 14:48:15,151 JiraImportTaskExecutionThread-1 ERROR admin 875x162x1 17m1ei6 10.32.126.106,0:0:0:0:0:0:0:1 /secure/admin/XmlRestore.jspa [jira.bc.dataimport.DefaultDataImportService] Error during ActiveObjects restore
com.atlassian.activeobjects.spi.ActiveObjectsImportExportException: There was an error during import/export with plugin Email This Issue(com.metainf.jira.plugin.emailissue) #7.0.21-jira6 (table AO_544E33_AUDIT_LOG_ENTRY):
at com.atlassian.activeobjects.backup.ImportExportErrorServiceImpl.newImportExportSqlException(ImportExportErrorServiceImpl.java:30)
at com.atlassian.dbexporter.importer.DataImporter$BatchInserter.flush(DataImporter.java:539)
at ...
at com.atlassian.dbexporter.importer.DataImporter$BatchInserter.executePS(DataImporter.java:515)
at com.atlassian.dbexporter.importer.DataImporter$BaseInserter.execute(DataImporter.java:473)
at com.atlassian.dbexporter.importer.DataImporter.importTable(DataImporter.java:127)
at com.atlassian.dbexporter.importer.DataImporter.access$000(DataImporter.java:35)
at com.atlassian.dbexporter.importer.DataImporter$1.call(DataImporter.java:75)
at com.atlassian.dbexporter.importer.DataImporter$1.call(DataImporter.java:64)
at com.atlassian.dbexporter.jdbc.JdbcUtils.withConnection(JdbcUtils.java:31)
at com.atlassian.dbexporter.importer.DataImporter.doImportNode(DataImporter.java:63)
at com.atlassian.dbexporter.importer.AbstractImporter.importNode(AbstractImporter.java:49)
at com.atlassian.dbexporter.DbImporter.importData(DbImporter.java:73)
at com.atlassian.activeobjects.backup.ActiveObjectsBackup.restore(ActiveObjectsBackup.java:164)
at com.atlassian.jira.bc.dataimport.DefaultDataImportService.restoreActiveObjects(DefaultDataImportService.java:572)
at com.atlassian.jira.bc.dataimport.DefaultDataImportService.performImport(DefaultDataImportService.java:773)
at com.atlassian.jira.bc.dataimport.DefaultDataImportService.doImport(DefaultDataImportService.java:332)
at com.atlassian.jira.web.action.setup.DataImportAsyncCommand.call(DataImportAsyncCommand.java:65)
at com.atlassian.jira.web.action.setup.DataImportAsyncCommand.call(DataImportAsyncCommand.java:28)
at com.atlassian.jira.task.ImportTaskManagerImpl$TaskCallableDecorator.call(ImportTaskManagerImpl.java:177)
at com.atlassian.jira.task.ImportTaskManagerImpl$TaskCallableDecorator.call(ImportTaskManagerImpl.java:148)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
