Hi
I am having a project to which the entire organization has access . But , I need to restrict the creation of issue in that project to only few users. How can this be made ?
Any help over this is highly valued.
Thanks.
First, by default JIRA has a horrible permission scheme that violates security best practices by allowing everyone that can logon to do just about everything.
JIRA works by GRANTING access. You can't restrict access. By default, it grants access to the group used to logon (see Global permissions to see the "can use" groups and admin groups). This is where users are getting their access.
This may be a big effort, but it will pay off down the road by making it easy to control access.
Most of the 'old timers' use project roles. It meets the best practice for security and gives complete control to the project lead for access to their project. JIRA comes with many project roles, but you can add more if you have a special need.
@Joe Pitt Thank you
This when you are logged in on Jira Service Management Backend
@Haran Kumar - You can accomplish this by doing the following:
Our documentation has some more in-depth instructions for things like this. I'm not sure which version of Jira you're using, but here's the doc for Jira Cloud: https://confluence.atlassian.com/adminjiracloud/managing-project-permissions-776636362.html
@Kevin Bui Thank you .
This leads to my next question on how to create a group with required users?
And to mention I'm using Jira cloud and I'm not the site admin.
