Rewire a groovy script as a post function
Derek Mart
Greetings!  First I wanted to thank the community for being so helpful.  I found a lot of good reference material in these forums to create the following script.  Now that I know it functions properly from the MyGroovy console, I need to remove stuff to make it work as a post transition function.
The problem is, I'm unfamiliar with the objects available at that time.  My script is complicated because I had to emulate the workflow transition environment.  I think I can remove the stuff I used for emulation: usermanager stuff, getprojectbykey, and getissuebycurrentkey.  I'm just not sure how to begin.
The script is designed to get the users from a role and add them to a Cc field upon ticket creation.  The need for this is based on project admins not having the ability to customize custom field contexts in our current version 7.10.2 and a great multitude of tickets are generated with requests for customizing this field.  I could find no other cheap solutions.
Suggestions and comments from the community are greatly appreciated.
import com.atlassian.jira.ComponentManager
import com.atlassian.jira.project.Project
import com.atlassian.jira.project.ProjectManager
import com.atlassian.jira.user.util.UserManager
import com.atlassian.jira.issue.CustomFieldManager
import com.atlassian.jira.security.roles.ProjectRole
import com.atlassian.jira.security.roles.ProjectRoleActors
import com.atlassian.jira.security.roles.ProjectRoleManager
import com.atlassian.jira.event.type.EventDispatchOption
ComponentManager componentManager = ComponentManager.getInstance()
CustomFieldManager customFieldManager = ComponentAccessor.getCustomFieldManager()
IssueManager issueManager = ComponentAccessor.getIssueManager()
UserManager userManager = ComponentAccessor.getUserManager()
ProjectManager projectManager = ComponentAccessor.getProjectManager()
ProjectRoleManager projectRoleManager = ComponentManager.getComponentInstanceOfType(ProjectRoleManager.class) as ProjectRoleManager
ProjectRole ccRole = projectRoleManager.getProjectRole("Default Cc")
MutableIssue issue = (MutableIssue) issueManager.getIssueByCurrentKey("TEST-123")
CustomField customField_CC = customFieldManager.getCustomFieldObject(10400)
List<ApplicationUser> userList = new ArrayList<>();
for (ApplicationUser userKey : (List<ApplicationUser>) issue.getCustomFieldValue(customField_CC))
userList.add(userKey)
Project project = projectManager.getProjectByCurrentKey("TEST")
ProjectRoleActors actors = projectRoleManager.getProjectRoleActors(ccRole, project)
for (ApplicationUser userKey : actors.getUsers())
userList = userList.unique()
ApplicationUser currentUser = userManager.getUserByName("johnsmith")
issue.setCustomFieldValue(customField_CC, userList);
issueManager.updateIssue(currentUser,issue,EventDispatchOption.ISSUE_UPDATED,false)
return userList
Derek Mart
Working Post Function:
import com.atlassian.jira.ComponentManager;
import com.atlassian.jira.project.Project;
import com.atlassian.jira.component.ComponentAccessor;
import com.atlassian.jira.event.type.EventDispatchOption;
import com.atlassian.jira.user.ApplicationUser;
import com.atlassian.jira.issue.Issue;
import com.atlassian.jira.issue.IssueManager;
import com.atlassian.jira.issue.MutableIssue;
import com.atlassian.jira.issue.CustomFieldManager;
import com.atlassian.jira.issue.fields.CustomField;
import com.atlassian.jira.security.roles.ProjectRole;
import com.atlassian.jira.security.roles.ProjectRoleActors;
import com.atlassian.jira.security.roles.ProjectRoleManager;
import com.atlassian.jira.security.JiraAuthenticationContext;
ComponentManager componentManager = ComponentManager.getInstance();
CustomFieldManager customFieldManager = ComponentAccessor.getCustomFieldManager();
ProjectRoleManager projectRoleManager = ComponentManager.getComponentInstanceOfType(ProjectRoleManager.class) as ProjectRoleManager;
ProjectRole ccRole = projectRoleManager.getProjectRole("Default Cc");
def currentUser = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
MutableIssue issueToUpdate = (MutableIssue) issue;
CustomField customField_CC = customFieldManager.getCustomFieldObject(10400);
userList.add(userKey);
ProjectRoleActors actors = projectRoleManager.getProjectRoleActors(ccRole,issue.getProjectObject());
userList = userList.unique();
issueManager.updateIssue(currentUser,issue,EventDispatchOption.ISSUE_UPDATED,false);
Derek Mart
network issue. duplicate post.
Nic Brough -Adaptavist-
November 1, 2018
There's not a huge amount to do here really.
I think all you need is to drop the lines about getting the project and issue, as the current issue is available already.
So replace "MutableIssue issue = ... " because the object "issue" will already be the issue.  But it is not a MutableIssue, so you'll need to cast it to use it later.  e.g. MutableIssue myIssue - (MutableIssue) issue ;
Then the project -
Can become
ProjectRoleActors actors = projectRoleManager.getProjectRoleActors(ccRole, issue.getProjectObject() )
Derek Mart
Thank you.
