Road Map Order on Summary of Project
Mark Scarantino
I can go into project administration and drag-n-drop the order of the versions.
When I go back to the summary page of the project, the roadmap is not displayed in thiss order. It seems to be in the order the versions were added. Is there any way to get them to display in the same order as the drag-n-drop form the administration version section?
Boris Georgiev [Appfire]
February 4, 2014
Which version of JIRA are you using? I tried this on 6.1.6 and it works as expected - the versions are displayed in the order they appear in the table (reversed) and if I drag n drop the order the summar page gets updated.
Nev Delap
November 9, 2014
It would sure be good if it didn't do it in reverse order, or you could set the order, especially since when you select "Upcoming 10 Versions" it simply doesn't show upcoming 10 versions, it shows the 10 most future versions which is probably never going to be very useful, and if you select all versions you have to scroll to the bottom find the upcoming next version.
Mark Scarantino
thanks. Was not expecting them to be in reverse order. Works great now that I understand that.
Thanks!!!!
