Running JIRA over SSL or HTTPS
vhall January 27, 2020
I am seeking clear instructions on how to configure HTTPS in Jira Tomcat web server. I am running Jira 8.1 on Windows 2016 server.
The following article; https://confluence.atlassian.com/display/JIRA044/Running+JIRA+over+SSL+or+HTTPS?_ga=2.182909730.505254273.1579714344-387228174.1565132255#RunningJIRAoverSSLorHTTPS-ImportCertificateIntoTheTruststore
is useful, but I am not familiar with keytool and we are using a wildcard cert currently available in .pfx format. (*.reflexionmedical.com).
Web Server details are as follows:
FQDN it Is technically jiratest.ad.reflexionmedical.com
JimmyVanAU
January 27, 2020
Consider running Jira behind a reverse proxy such as nginx, and let that do all of the heavy lifting.
This blog post outlines the steps - https://blog.servicerocket.com/adoption/blog/2014/07/3-steps-in-set-up-nginx-as-proxy-server-for-atlassian-jira
It's similar to Atlassian's knowledge base article - https://confluence.atlassian.com/jirakb/configure-jira-server-to-run-behind-a-nginx-reverse-proxy-426115340.html - with the addition of the https side of things. You can otherwise follow the Atlassian article, then have a look at how to use nginx as a reverse proxy. nginx can easily run on your existing Windows 2016 server as it has a very small footprint.
Adrian Stephen
January 27, 2020
Hi @vhall
Welcome to the Atlassian Community.
If you are using a .pfx  format cert, you may follow the steps from this article :
May I know if you have tried the steps from the article above?
Do keep us updated with the progress & have a great day!
Regards ,
Adrian Stephen
vhall January 28, 2020
Thank you Adrian. Once I have the wildcard cert, I will follow the instructions per article provided and keep you informed.
Like Adrian Stephen likes this
