Running Jira applications over SSL or HTTPS
Matteo Brandolini January 14, 2021
I try to follow this link
https://confluence.atlassian.com/adminjiraserver/running-jira-applications-over-ssl-or-https-938847764.html
to install signed certificate (CA reply) and a set of root/intermediate CA certificates.
I arrive at point 2) of section "Configuring your web server using the Jira configuration tool" but when I click "check certificate in key store" I receive an error.
Is this guide not updated?
I wait your reply.
Mohammad_Mishrif October 29, 2024
Hi all,
I know it's too late, but I think it's good to provide a direct answer here
I see the issue here cause of: Wrong Alias name
You've to type in field (Key Alias): the Alias name that you've previously generated & stored at .jks file
Nic Brough -Adaptavist-
January 14, 2021
The guide is up to date and works fine - one of my collegues was using it yesterday.
What error are you getting?
SERVER
