×Error is:
Attempting to connect to the MySQL database server...
Could not connect to the DB: Communications link failure
The last packet sent successfully to the server was 0 milliseconds ago. The driver has not received any packets from the server.
I've modified the dbconfig.xml in $JIRA_HOME per your recommendations on your site and still get the error. I've also tried different ports for MySQL and still the same error. Help please!
Contents of dbconfig.xml:
<jira-database-config>
<name>defaultDS</name>
<delegator-name>default</delegator-name>
<database-type>mysql</database-type>
<jdbc-datasource>
<url>jdbc:mysql://localhost:3306/jira?useUnicode=true&characterEncoding=UTF8&sessionVariables=storage_engine=InnoDB</url>
<driver-class>com.mysql.jdbc.Driver</driver-class>
<username>jira</username>
<password> jira</password>
<pool-min-size> 20</pool-min-size>
<pool-max-size> 20</pool-max-size>
<pool-max-wait> 30000</pool-max-wait>
<validation-query>select 1</validation-query>
<min-evictable-idle-time-millis>60000</min-evictable-idle-time-millis>
<time-between-eviction-runs-millis>300000</time-between-eviction-runs-millis>
<pool-max-idle> 20</pool-max-idle>
<pool-remove-abandoned> true</pool-remove-abandoned>
<pool-remove-abandoned-timeout> 300</pool-remove-abandoned-timeout>
<pool-test-while-idle> true</pool-test-while-idle>
<validation-query-timeout>3</validation-query-timeout>
</jdbc-datasource>
</jira-database-config>
Well, MySQL cannot be contacted. However, this is just a generic exception wrapped on the real cause. Please check the logs, and look for "caused by" stach trace. That should tell you what's wrong.
