Running fresh Jira install on Linux
Joshua Nass April 28, 2013
It's been over six months since my last Jira install and that was on a much more "open" system.
Today I have a dedicated user "jirasvc" with sudo privilages. I have installed Jira as a service and when I try and run start-jira.sh with the jirasvc user I get a complaint that the user is not the expected "jira" user.
I understand that during the install process Jira attempts to create a new user and set it with the appropriate access rights to the files. However on this system, that is impossible as it is very locked down.
How do I run jira with jirasvc and avoid further complication?
Thank you!
Tiago Comasseto
April 29, 2013
Hi Joshua,
JIRA installer is good for almost all the Linux environments, but in some cases I believe the tar.gz distribution is better.
Also, you can use these instructions to create a start up script and choose the user account you want to execute the script.
I hope this helps.
Cheers
Are you saying that by creating the startup script start-jira.sh will no longer require user "jira" be the one that runs it?
Harry Chan
April 29, 2013
Or you can modify start-jira.sh if you have the permissions to.
