We want to use JIRA software for
1. Project management using SCRUM
2. Version control of the code
3. Build and Release management
I need step-by-step guide to install different supporting softwares and make the whole workflow simple.
Please share a consolidated information for all the above requirements.
Apologies Rupali, I don't know a link with all this info but here is how to integrate Jira, Bitbucket/Stash & Bamboo: https://confluence.atlassian.com/bamkb/beauty-of-integration-in-a-suite-of-three-bamboo-jira-and-stash-integration-686859431.html
Regarding workflow, I would use the out the box (simple workflow) solution first and then start playing around once you have used the Scrum boards for a while (when you setup a Scrum board, it automatically creates a workflow for you).
Depending on team size (and requirements), perhaps use the cloud version of products as they are designed to be easier to administer.
You can read helpful hints here: https://www.atlassian.com/blog
Good-luck ;)
Hi Rupali,
I would have a look at this page: https://confluence.atlassian.com/get-started-with-jira-software/get-started-with-jira-software-937185118.html
This has all the documentation you will need to setup your team/project.
Kind Regards,
Brett
Thanks Brett.
I could not find the information about Bitbucket, Confluence, Bamboo or any other tool required for the entire workflow together.
I am looking for such information at one common link.
Rupali
