JIRA's SCHEMEPERMISSIONS table consists of the following columns.
ID, SCHEME, PERMISSION, PERM_TYPE, PERM_PARAMETER
To where should I join PERMISSION column?
I couldn't find any table containing the set of permission types.
Thanks!
Shaakunthala
You can use this query (PostgreSQL):
SELECT PS.name AS PermissionSchemeName,SP.perm_parameter AS GroupName, SP.permission_key AS Permission
FROM schemepermissions SP
INNER JOIN permissionscheme PS ON SP.scheme = PS.id
ORDER BY 1, 2, 3;
These are hardcoded constants within the JIRA codebase (see https://docs.atlassian.com/jira/latest/com/atlassian/jira/permission/Permission.html for Javadoc details of the `Permission` ENUM). There is a full list here: https://docs.atlassian.com/jira/latest/constant-values.html#com.atlassian.jira.security.Permissions.ADMINISTER
Hey there, Sameera.
Perhaps you can check on the following documentation. You might be able to find what you are looking for:
https://confluence.atlassian.com/display/JIRACOM/Example+SQL+queries+for+JIRA
Warm regards,
Danial
Looking at the following Javadoc, I think this is not something we can query using SQL.
http://docs.atlassian.com/jira/latest/com/atlassian/jira/security/Permissions.html
I forgot to add a justification to what I said above.
According to the Javadoc provided, all the permission items are actually integer constants. They seem to be hardcoded into JIRA so it is not possible to retrieve that information using SQL.
