I am working to help identify who is using my JIRA application (server 7.13.x) and curious if someone could share a SQL query to display number of JIRA issues per user.
Would be nice to include the name, email and number of issues within the last X months (if possible)
TIA
Hello, Mike. I can offer you a ready-made report that works as a rest service on the free plugin mygroovy. Your users will at any time be able to access such a report via a link in Jira. The configuration is as simple as possible; just insert a piece of code by changing a few variables: filter, userName, password
If you need the ability to limit the report to groups, change the variable groups to the desired
I got a lot of code, so I’ll put it in here: https://paste.ofcode.org/cyDfHPAmncFvDXxVPzZLNM
Hi Mike,
We detect user activity not by user / number of issues, but we verify count and date of last login to Jira. Not every user has to create in Jira issue, but can only read or comment, etc.
Here is our SQL:
SELECT
DISTINCT
u.lower_user_name, to_timestamp(
CAST
(last_login
AS
BIGINT
)/1000)
AS
"Last Login"
, login_count
FROM
cwd_user u
JOIN
cwd_membership m
ON
u.id = m.child_id
AND
u.directory_id = m.directory_id
JOIN
licenserolesgroup lrg
ON
Lower
(m.parent_name) =
Lower
(lrg.group_id)
JOIN
cwd_directory d
ON
m.directory_id = d.id
LEFT
JOIN
SELECT
ca.user_id, ca.attribute_value
as
last_login
FROM
cwd_user_attributes ca
WHERE
attribute_name =
'login.lastLoginMillis'
AS
a
ON
a.user_id = u.id
LEFT
JOIN
SELECT
as
login_count
FROM
WHERE
attribute_name =
'login.count'
AS
b
ON
b.user_id = u.id
WHERE
d.active =
'1'
AND
u.active =
'1'
AND
license_role_name =
'jira-core'
AND
u.lower_user_name
not
in
SELECT
u.lower_user_name
FROM
cwd_user u
JOIN
cwd_membership m
ON
u.id = m.child_id
AND
JOIN
ON
Lower
(m.parent_name) =
Lower
(lrg.group_id)
JOIN
cwd_directory d
ON
WHERE
d.active =
'1'
AND
u.active =
'1'
AND
license_role_name
in
'jira-software'
'jira-servicedesk'
ORDER
BY
"Last Login"
DESC
Here is SQL result:
lower_user_name | Last Login | login_count
user1 | 2017-12-13 11:50:18+01 | 901
user2 | 2017-12-13 11:48:28+01 | 899
user3 | 2017-12-13 11:32:54+01 | 295
Pavel
