Is there a SQL way to retrieve Issues added or removed from a sprint? I am not looking for JQL options.
Best I can tell, you need to look in two places:
For #1 (Issues Created After the Start of the Sprint)
SELECT
b.NAME SprintBoardName,
b.ID SprintBoardID,
S.NAME SprintName,
s.ID sprintID,
convert(date,DATEADD(SECOND, s.start_date / 1000, '19700101 00:00')) SprintStart,
p.pkey+'-'+cast(i.issuenum as NCHAR(10)) IssueKey,
i.id IssueId,
convert(date, i.created) IssueCreated,
convert(date,i.RESOLUTIONDATE) IssueResolutionDate
FROM customfieldvalue c,
jiraissue i,
project p,
AO_60DB71_SPRINT s
left join AO_60DB71_RAPIDVIEW b on b.ID=s.RAPID_VIEW_ID
where i.project=p.id
and i.ID=c.ISSUE
and c.CUSTOMFIELD = 10000
and s.ID=CAST(c.STRINGVALUE as int)
and (i.RESOLUTIONDATE is null or i.resolutiondate >= DATEADD(m, -6, current_timestamp))
and (s.start_date is null or convert(date,DATEADD(SECOND, s.start_date / 1000, '19700101 00:00')) >= DATEADD(m, -6, current_timestamp))
and convert(date,DATEADD(SECOND, s.start_date / 1000, '19700101 00:00')) < convert(date,i.created)
For #2 - Issues that have Sprint values Changed. (this example pulls all Sprint Changes for the last 6 months)
SELECT
i.id IssueId,
convert(date,cg.created) as ChangeDate,
case when ci.oldstring is null then ' ' else ci.oldstring End SprintOld,
case when ci.newstring is null then ' ' else ci.newstring End SprintNew
FROM jiraissue i,
project p,
changeitem ci,
changegroup cg
where
and i.project=p.id
and cg.issueid = i.id
and ci.groupid = cg.id
and ci.field = 'Sprint'
No, the data is not recorded in the database. Unless it's a scope change in an active sprint.
Yes, I am referring to once the sprint starts, issues added and removed from an active sprint. Is there a way to query it?
