Dear Experts,
I want to fetch all issues details (Issue Key, Project, Project Key, Summary, Reporter, Created Date, Resolution date, Status, XYZ) from specific project created between 1st Jan 2025 to 31st Jan 2025 along with Cascaded custom field value.
Project: ABC
Cascaded Field: XYZ (XYZ1, XYZ2)
XYZ1 : Asia, Europe
XYZ2 for Asia : India, Japan, China
XYZ2 for Europe: Germany, Sweden
Could you please help me to get correct query.
Hi @RG
If you're looking for SQL queries, and that's not a typo in the subject, you can see the SQL schema here: https://developer.atlassian.com/server/jira/platform/database-schema/
You're probably going to use these tables:
* jiraissue
* project
* customfield
* customfieldvalue
Hi @RG
Getting all the issues its easy, the query is
project = namehere and createdDate >= "2025-01-01" and createdDate <= "2025-01-31"
Now about the fields you mention, you can get that information by adding the fields in to the columns. go to the icon below JQL:
Then you will see the fields on the screen and you can export them to CSV or any other file.
BUT you cannot get the field's context (values for each field).
Regards - Aaron
Hi @Aaron Pavez _ServiceRocket_ Thanks for your help. I am looking for DB query to fetch all records from specific project.
JQL not allowing me to fetch more than 2000 records and we have more than 100k records for each Cascaded values.
Hi @RG
Can you please try this query and check the result
SELECT
IssueKey, Project, ProjectKey, Summary, Reporter, CreatedDate, ResolutionDate, Status, CascadedFieldValue
FROM
IssuesTable
WHERE
Project = 'ABC'
AND CreatedDate BETWEEN '2025-01-01' AND '2025-01-31'
AND (CascadedFieldValue IN ('Asia', 'Europe', 'India', 'Japan', 'China', 'Germany', 'Sweden'));
Explanation of the query:
Cascaded Custom Field Filter: Filters the values for XYZ (both XYZ1 and XYZ2) based on your hierarchy.
Make sure to update the table name (IssuesTable) and column names (CascadedFieldValue, etc.) based on your database structure.
