SQL query for Project name, category and workflow
Ron Jacob
Hi
Can you tell me SQL query to get Project name, category and workflow name ?
M Amine
Hi Ron,
Try looking to this answer : here
  • Mapping project with ProjectCategory
select * from project where ID in (select SOURCE_NODE_ID from nodeassociation
where ASSOCIATION_TYPE = 'ProjectCategory' and SINK_NODE_ID=10100);
where 10100 is the id of 'ProjectCategory'.
and this answer : here
  • Mapping project with workflow
SELECT *
FROM PROJECT, NODEASSOCIATION, WORKFLOWSCHEME
WHERE PROJECT.ID = NODEASSOCIATION.SOURCE_NODE_ID
AND NODEASSOCIATION.SINK_NODE_ID = WORKFLOWSCHEME.ID
AND PROJECT.ID = '11630'
where 11630 is the id of the project.
cheers
Fabio Racobaldo _Catworkx_
Hi @Ron Jacob ,
here your SQL :
select ji.*
from nodeassociation na
inner join project p on (p.ID = na.SOURCE_NODE_ID)
inner join projectcategory pc on (pc.ID = na.SINK_NODE_ID)
inner join jiraissue ji on (ji.PROJECT = p.ID)
where na.ASSOCIATION_TYPE='ProjectCategory' and na.SOURCE_NODE_ENTITY='Project'
and pc.cname='YOUR PROJECT CATEGORY NAME HERE';
Hope this helps,
Fabio
