SQL query to fetch Issues created in certain project between two given dates
Ramakrishna _RK_
October 8, 2019
Hello!!
Can some one helped me in writing SQL query to fetch from DB directly for below JQL.
Project = "ABC" AND Issuetype in (Task,Story) AND createdDate >= "2019-09-01" and createdDate < "2019-10-01"
Thanks  in Advance!!
Regards
Ramakrishna
fran garcia gomera
October 8, 2019
select * from jiraissue.ji
where ji.issuetype in
(select id from issuetype where pname in ('Task','Story'))
and ji.project in
(select id from project where pname in ('ABC'))
-- or
--(select id from project where pkey in ('ABC'))
-- if ABC is the project key instead of the project name
and CREATED > '2019-08-31' -- to get 2019-09-01 included, CREATED is time/hour
and CREATED < '2019-10-01'
RianS
October 8, 2019
Here's a search some SQL you can try
For Postgres:
SELECT jiraissue.* FROM jiraissue
INNER JOIN project ON jiraissue.project = project.id
INNER JOIN issuetype ON jiraissue.issuetype = issuetype.id
WHERE
project.pkey IN ('PROJECTKEY')
AND issuetype.pname IN ('Task','Story')
AND jiraissue.created >= '2019-09-01'
AND jiraissue.created < '2019-10-01'
ORDER BY jiraissue.issuenum;
For Oracle:
WHERE
AND jiraissue.created >= to_date('2019-09-01', 'YYYY-MM-DD')
AND jiraissue.created < to_date('2019-10-01', 'YYYY-MM-DD')
This should give you the issues you are looking for.
