I have a running instance of JIRA 4.2 with integrated SSO, and we are in process of upgrading JIRA to 5.2. When i setup the SSO integration aby put and modify all the related files, it redirects perfectly on SSO url but come back to JIRA showing some error like "java.lang.AbstractMethodError". I have attached a error of above error.
Cause:
java.lang.AbstractMethodError: com.atlassian.configurable.SMAunthenticator.getUser(Ljava/lang/String;)Ljava/security/Principal;
Stack Trace: [hide]
java.lang.AbstractMethodError: com.atlassian.configurable.SMAunthenticator.getUser(Ljava/lang/String;)Ljava/security/Principal; at com.atlassian.configurable.SMAunthenticator.getUser(SMAunthenticator.java:40) at com.atlassian.seraph.filter.SecurityFilter.doFilter(SecurityFilter.java:132) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210) at com.atlassian.security.auth.trustedapps.filter.TrustedApplicationsFilter.doFilter(TrustedApplicationsFilter.java:98) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210) at com.atlassian.seraph.filter.BaseLoginFilter.doFilter(BaseLoginFilter.java:169) at com.atlassian.jira.web.filters.JiraLoginFilter.doFilter(JiraLoginFilter.java:70) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:66) at com.atlassian.oauth.serviceprovider.internal.servlet.OAuthFilter.doFilter(OAuthFilter.java:55)
Hi Panguin
Are you using Crowd or a custom SSO authentication? In this case, please don't forge to add the new class in the related Tomcat classes path.
Perhaps the following link could be useful to understand a little bit about this:
https://confluence.atlassian.com/display/CROWD/Overview+of+SSO#OverviewofSSO-ConfiguringCrowdforSSO
Paulo Renato
It is a custom authenticator, the getUser method is giving problem...
getUser(String arg0) is giving problem; last time it was a method in DefaultAuthenticator, but now in JIRA API it is a abstract method now. so i got to implement the getUser(String arg0) on my own.
Anyone can share how to implement getUser(String arg0) in the getUser(request, response)????
